Results 1 to 7 of 7
Thread: Took softener off Bypass and now no water in the house???????
    DIY Junior Member Jsalesc's Avatar
    Nov 2011
    West Point Ut
    Default Took softener off Bypass and now no water in the house???????
    Hello,
    We had house sit empty for a year so we put our water softener on Bypass, Well someone moved in and we went to put it back off bypass and
    now we have no water in the house! What could be the problem what do we need todo or do we just need to call a plumber thanks so much!!!!!
    Put it back in by pass and then determine what is stopping water flow through the softener. It could be the bypass valve.
    Plumbers do not normally know how to troubleshoot softeners so it is better to research the 'net and do it yourself or pay a water treatment dealer to come out and do it for you. You find them in the yellow pages etc.. Or... call the place you bought it from.
    Dec 2009
    Alaska
    When you put the unit into bypass did you have it first do a regen?
    Could be that the media after setting for a year or more dirty is not letting the water through and a regen or two will correct the flow challenge.
    Is this city water or well water?
    Age of the system in question?
    Nov 2010
    Maine
    Cycle the valve manually.
    Nice try but not today, it's a pointless and unsupportable argument
    DIY Member rjh2o's Avatar
    May 2011
    Michigan
    It probably has a plugged manifold or a plugged upper basket. If the bypass is a slide valve on the back of softener it probably is one of the latter. If the bypass is a "three valve bypass" the valves may be bad, especially if they are gate valves.
    RJ
    Nov 2011
    West Point Ut
    its 13 years and it has a slide valve and we have city water. We get water to the cold in the kitchen but no water anywhere else and no hot in the kitchen we have regenerated it once but still not working
    Dec 2009
    Alaska
    Water to the kitchen sink, cold side sounds like it has a feed that is from before the softener.
    If the slide bypass is in by pass is there water to the full house?
    If the bypass in bypass there is water but no water when the bypass is in service , then I would be looking at some thing in the valve as a block to the water flow.
  1. Water Softener On = No Pressure, Bypass = Normal Pressure?
    By jsarin1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2011, 04:06 PM
  2. Softener hookup issue - 1" bypass, 3/4" Main
    By adawg in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2010, 02:09 PM
  3. Water Pressure Booter Pump w/softener and whole house filter
    By dsteph3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2010, 06:12 AM
  4. Water Softener Bypass Plug Leak
    By sasha7771 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2008, 07:58 PM
  5. Copper Bypass Drawing for Water Softener
    By weneedhelp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2007, 08:12 PM
