Results 1 to 7 of 7
Thread: Insulating Outlet/Light Boxes
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Insulating Outlet/Light Boxes
    Are there any techniques that can be recommended for reducing the draft in a outlet/light boxes (specifically a box with 3 light switches?)
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    Retrofit is difficult but in new construction use tape to close off all the holes in the box and some spray foam or caulk to seal the wire penetration. Use some siliconized latex caulk to seal between the edge of the box and the drywall.
    They sell inexpensive foam pieces designed to fit over the switch or receptacle. For multi-gang ones, you can overlap them. They'll help with the breeze.
    Sep 2006
    cold new york
    Is Spray foam in the box OK?
    Gore Vidal.
    Jun 2007
    North Carolina
    Quote Originally Posted by molo View Post
    is spray foam in the box ok?
    no .
    Jan 2008
    If you are really motivated, you might consider opening up the wall to see where all that air is coming from. You may have a big leak or the insulators could have "missed" a stud bay.
    Usually the problem is "OUTSIDE" the box and needs insulation around it.
  1. Converting Light Fixture Box To Powered Outlet
    By Kiko in forum Electrical Forum discussion & Blog
    Last Post: 02-04-2011, 06:23 PM
  2. Light > Switch > Outlet
    By dan121 in forum Electrical Forum discussion & Blog
    Last Post: 09-08-2010, 05:43 AM
  3. Light Switch to turn on wall outlet
    By coopns in forum Electrical Forum discussion & Blog
    Last Post: 02-08-2010, 04:22 PM
  4. How to make light switch/outlet connection.
    By bjferri in forum Electrical Forum discussion & Blog
    Last Post: 08-18-2007, 07:02 PM
  5. wood paneling and outlet boxes
    By penultimatum in forum Electrical Forum discussion & Blog
    Last Post: 07-29-2007, 07:19 AM
