I have a well with submersible pump. My house is a slab. We have had a lot of air in the water line. All of them-(the sinks, toilets ) sound as if they are going to blow up when the water is turned on. I had a plumber come out. He checked my pressure tank-it is o.k. The cut in/cut off on the pressure switch makes a load noise also.The plumber said I had a leak in the pipe somewhere from the well to my house. I dug around the well-no leak there. I dug down to where the black pipe meets the foundation of the house. It is a bit muddy, but no obvious leak. How do I found out where the leak is? I think it may be under my house. Is there a way to find out for sure(without tearing the house up??!!)
