Results 1 to 5 of 5
Thread: Breaker keeps tripping
    Default Breaker keeps tripping
    My 220V 20 amp breaker for my well pump will not reset after it trips. Any ideas? Thanks!
    You have a direct short somewhere in the wiring. Have an electrician or pump/well person check it out for you.
    Ron
    Previous member
    Jul 2005
    Riverview, Fl.
    Did you turn it all the way off then back to the on position? This resets it. If you just turn toward on, it will not catch.
    bob...
    DIY Senior Member rshackleford's Avatar
    Oct 2005
    middle of nowhere
    I had a customer last week with a bad breaker. We firgured this out becuase the thing wouldn't reset when the main breaker was off. Well, we talked on the phone, determined it could be a bad breaker, and i haven't heard back. I have talked the business since, but no mention of a pump problem. This is probably the exception to the rule.
    rshackleford
    WOW--O&A Party Rocks
    Easiest way to check the breaker is to remove the load wires,then try to reset. If it won't reset w/o the load wires attached, it's dead.
