Results 1 to 9 of 9
Thread: Water gurgling right at drain new sink
    DIY Junior Member PGragg's Avatar
    Sep 2011
    falls church, VA
    Default Water gurgling right at drain new sink
    Just put in new vanity and vessel sink. Contractor had to reconfigure piping under sink with PVC. Sink came with pop-up stopper and tail piece. Loud water noise right below sink hole of water running through and some as it runs down PVC pipe to p trap. How do I fix it? It's loud and annoying but appears to be related to materials not any venting problems. Not a burgling, bubbling gurgle just trickling sounds.
    quote; Loud water noise right below sink hole of water running through and some as it runs down PVC pipe to p trap.
    I have no idea what that means. What is the "sink hole" and is it running down the outside of the PVC pipe? Is the trap under the sink drain or off to the side?
    If it's draining quckly, then there will be more noise.
    Some lav drains are so gooed up, that they no longer drain quckly.
    Can you post a picture?
    800 pixels or less.
    Feb 2011
    NW Ontario, Canada
    If the popup is adjustable, set it so it doesn't open as wide and it will drain slower. Why did the contractor have to use PVC? Metal would be more quiet.
    Nov 2010
    Maine
    I think I would call the contractor back. Was this a plumbing contractor?
    Mar 2011
    Long Island, NY
    Quote Originally Posted by PGragg View Post
    I also installed a vessel sink with a pop up stopper. The sink has no overflow hole, which a normal lav sink has, and water going down the drain pulls air down with it, air maybe that a normal sink with overflow would aid the water going down the tail piece quietly. My DIY 2 cents homeowners opinion. the noise never bothered me though, but it does exist. think of it as sounds of tranquility
    Sep 2011
    falls church, VA
    Thanks everyone for your comments. If you see another thread on this, sorry. I couldn't find my original thread. My husband thinks the noise is loud because the contractor immediately stepped up the pipe size to 2" PVC. My husband thinks the piece under the tailpiece should be the same size and metal and go a little ways and then step up to the bigger pipe size. That's what the other sinks in my house have if they have to run a long ways down to mee the p trap. What do you all think?
    Not likely, but since we cannot hear the gurgling, (and "gurgling" can mean many things and have many causes), or see HOW he configured the drain line, (it is NOT likely to be 2" however), we cannot diagnose, or even comment, on it.
    Feb 2011
    NW Ontario, Canada
    ...or see HOW he configured the drain line, (it is NOT likely to be 2" however), we cannot diagnose, or even comment, on it.
    A picture is worth a thousand words.
    I would terminate the PVC at the wall and go with an all metal trap and tailpiece.
  1. Dishwasher gurgling through sink
    By lcuga13 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2014, 11:39 PM
  2. Gurgling Sink After Remodel
    By JasonG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2008, 03:09 PM
  3. Loud - gurgling - bathroom sink drain
    By 67stang in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2008, 06:52 AM
  4. kitchen sink gurgling
    By ddurand in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2007, 04:50 AM
  5. gurgling sink
    By pman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-29-2005, 05:04 PM
