Jlukasavige
- Messages
- 9
- Reaction score
- 0
- Points
- 0
I posted a problem that I'm having with a water heater in a previous thread: https://terrylove.com/forums/showthread.php?t=4242
Now, I'm pretty sure that it's a problem with the pressure regulator on the house.
I just hooked up a pressure guage to an outside faucet and I'm getting 140 psi. I'm assuming that this is way to high. I've heard 80 is normal. I took a picture of the regulator and that can be seen by clicking here: http://home.nc.rr.com/lukasavige/Img2005-11-07_0001.jpg
I've turned the nut on the valve both ways, but the pressure does not change from 140 psi.
I don't have any PEX tools. Is there and easy way to replace this? I have decent soldering skills as long as I can get the water out of the pipes. I'd also replace that shutoff valve with a 1/4 turn levered ball valve.
Thanks for the help.
