Results 1 to 8 of 8
Thread: Bonding when 2 circuits in one box?
    DIY Senior Member jch's Avatar
    Jan 2006
    Victoria, British Columbia, Canada
    Question Bonding when 2 circuits in one box?
    I have a wall switch box that will have 2 circuits in it:
    1) A pass-through circuit with just a junction between incoming and outgoing wires; and
    2) A light switch at the tail end of a separate circuit.
    I have attached Circuit #2's bonding wire to the box because it is the circuit that is powering the switch.
    Questions:
    a) Do I need to also attach Circuit #1's bonding wire to the box? Circuit #1 is just passing through the box (with a junction inside the box).
    b) Do I need to make sure that both circuits are on the same phase? Or is it okay for them to be opposite phases?
    Thanks,
    - John
    Jun 2009
    Canada
    Everything in the box has to be tied together and tied into the box, afaik.
    Jan 2008
    I cannot answer the question with certainty, but I do look forward to further explanation if that is true.
    IMO, if the box is bonded, (which it is required to be if it is metal), I don't see any benefit to attaching the other conductor only because it passes through the box. This would only create another splice, which again, IMO is unnecessary.
    Jun 2007
    North Carolina
    All equipment grounding conductors that enter the box are to be tied together with the largest being bonded to the box.
    Jun 2009
    Canada
    IMO, if the box is bonded, (which it is required to be if it is metal), I don't see any benefit to attaching the other bonding conductor only because it passes through the box. This would only create another splice, which again, IMO is unnecessary.
    It's a redundancy thing though...
    Jan 2006
    What I'm doing is moving the light switch on to a different circuit and preserving the original circuit's connections to the downstream outlet(s).
    It's a plastic box (if that matters).
    - John
    Feb 2011
    NW Ontario, Canada
    It sounds like you might be exceeding the maximum number of conductors in the box. What size box and how many conductors?
    Jun 2007
    North Carolina
    Quote Originally Posted by jch View Post
    there is no need to bond a nonmetallic box
  1. bonding/grounding and pex
    By peltaz in forum Plumbing Forum Discussion & Blog
    Last Post: 10-23-2009, 05:39 AM
  2. Bonding
    By Bgood in forum Electrical Forum discussion & Blog
    Last Post: 06-17-2009, 04:01 AM
  3. Metal Bonding?
    By molo in forum Plumbing Forum Discussion & Blog
    Last Post: 08-14-2007, 06:49 AM
  4. pvc not bonding
    By foghat35 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-08-2007, 07:20 PM
  5. Solderless Copper Bonding
    By ufodriver2 in forum Plumbing Forum Discussion & Blog
    Last Post: 12-14-2004, 11:38 AM
