Results 1 to 8 of 8
Thread: Convert Plug-in to Hard-Wire Connection
    Default Convert Plug-in to Hard-Wire Connection
    My 18 year old 30 gallon electric water heater (240v/3500w) now plugs into a wall receptacle served by a 20a double breaker. The water heater just gave up the ghost and started leaking. The replacement is a similar sized/similar powered unit but code now specifies that the connection should be hard-wired.
    Do I just remove the existing plug cover and receptacle, wire nut the new wires into the box, pass them through a metal face plate into bx joined to the face plate, then to the water heater? The service to the water heater is with #12 wire in rigid conduit to a metal box at the wall.
    Is that the proper way to convert this setup or is there some other consideration/material to use that make it a proper connection?
    Thanks...Stan
    Jun 2007
    North Carolina
    Stan
    Two things comes to mind here. First is the new water heater a 3500 watt? If it is a 4500 watt water heater the #12 will be to small. Second, is there a disconnect for the water heater within sight and no more than 50 feet away or a lock out on the breaker? If not replace the receptacle with a no fuse disconnect and proceed
    Thanks for a quick response
    Yeah, the new unit is 3500 watts. The breaker is only 20a with #12 wire, so that is about the max I can put in. Well maybe a 3800 watt unit would be borderline OK. That means that without upgrading the circuit to #10 and a new breaker, I'm stuck with 3500w. The water heater is in a closet on the patio of our townhouse/villa. It is about 5' away from the main panel which is just inside the front door of the villa. There is /no/ disconnect in the closet. I suppose the "disconnect" on the existing water heater was one of those "pull the plug out" styles of disconnect So I guess I will need to use a no fuse disconnect. I'll have to shop for something like that, do you know if it would fit inside the existing box or on top of the existing box?
    Jun 2007
    North Carolina
    A plaster ring and a 20amp toggle (light switch) will work great. Using an extension ring on the existing box (assuming it is a 4 square) gives access for the cable to the unit to be attached
    Just make sure the switch is a two-pole version (so it can switch both legs), and rated for the load.
    That's a nice approach. I was thinking I would have to find a large style of non-fusible disconnect metal box like are used for A/C's. And something like this (appropriately rated/two pole <---Thanks Jim!) would be code-approved by the inspector?
    Jun 2007
    North Carolina
    yes .
    Great, much thanks...Stan
  1. New 220 4 wire stove and old 220 three wire plug
    By Wardsweb in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2010, 05:44 AM
  2. New range - 3 wire connection
    By Kleggo in forum Electrical Forum discussion & Blog
    Last Post: 11-02-2009, 06:18 AM
  3. How hard to convert floor to rear drain?
    By davidq in forum Toilet Forum discussions
    Last Post: 09-20-2009, 12:48 PM
  4. To plug or not to plug into a GFCI outlet
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 04-15-2009, 04:13 PM
  5. Well casing ground wire connection
    By MarkHash in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-10-2008, 05:06 PM
