If it will work depends completely on the pumping capacity of the washer. If I had to do such a thing, I would pump the water into a laundry sink which only requires a 1-1/2 drain.
The reason the code is 2" is because many washers will pump out faster than a 1-1/2" standpipe can drain.
It is grandfathered only if it was legal in the first place AND you do nothing to change it.
