Results 1 to 2 of 2
Thread: tk3 turns on to often
    DIY Junior Member dh100m's Avatar
    Jan 2011
    ontario canada
    Default tk3 turns on to often
    My takaki tk3 works fine but even when the toilets flush it turns on for 5 sec or so then shuts off
    I am on a well with average water pressure of 40lb The company did not respond to my inquiry
    any help would be appreciated
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    The low pressure in the piping system causes the water in the hot side flowing backwards through the heater. After cold water draw stops, the piping system re-pressurizes including the hot water piping, causing brief flow through the heater. When this happens unit fires as designed since it senses flow through the tankless. A good spring loaded check valve on the cold water inlet of the tankless will solve this issue.
    If Payback is so important to you, why are you not driving a Toyota Corolla?
  1. bathtub faucet turns on by itself
    By sproksch in forum Shower & bathtub Forum & Blog
    Last Post: 10-16-2010, 04:47 PM
  2. Barbie turns 50
    By Redwood in forum Computers and Stuff
    Last Post: 03-28-2009, 06:24 PM
  3. Well pump turns on every 30 min. HELP
    By Steve H in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-02-2007, 08:44 AM
  4. PEX and tight turns...
    By OldPete in forum Plumbing Forum Discussion & Blog
    Last Post: 03-29-2007, 07:51 PM
  5. shower the valve turns on by it's self
    By ghostvalve in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2006, 07:19 PM
