Results 1 to 2 of 2
Thread: Toto Drake red flapper vs blue flapper
    DIY Junior Member DSWWPB's Avatar
    Dec 2010
    Florida
    Default Toto Drake red flapper vs blue flapper
    Hi All, been lurking here for info on toilets since I needed to replace one. Chose a Toto Drake 1.6. I was VERY skeptical going from a 3.5 toilet to anything less than that which is why I chose the Drake 1.6 over the Drake II 1.28. I must say I'm pleasantly surprised. The Drake 1.6 flushes much better than the 3.5 Briggs it's replacing. But, because I was so skeptical I bought a Lowes blue flapper right after buying the Drake toilet. Info here stated the blue flapper stayed open longer and gave a better flush at the expense of a little more water /flush. Since I already had it, I tried it in the new Drake even though the red flapper was giving a surprisingly quick but strong flush. The blue flapper does stay open a bit longer, gives more bowl wash and possibly a longer/stronger flush. Unscientific testing shows it lets in 2more qts (64 oz) of water out of the tank versus the red flapper. I will wait until my 375 lb buddy "tests out" the new Drake before I make a decision on whether I'll put the red flapper back in.LOL
    I won't hesitate to replace the other toilet with a 1.28 Drake II knowing that I can always change the flapper to get a 1.6ish flush if I think it's necessary. Very impressed with Toto toilets
    DIY Member BlueHouse's Avatar
    Aug 2011
    New York, NY
    The blue flapper is Power Gravity. The red is E-Max. Power Gravity is 1.6 while E-Max is1. 28
  1. Power Gravity (blue) Flapper in a Drake & Drake 2 (Gwyneth)
    By tyneskj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2009, 03:27 PM
  2. Is it possible to put a 3.5 gallon flapper in a Toto Drake?
    By deebee in forum Toilet Forum discussions
    Last Post: 08-02-2008, 03:37 PM
  3. My findings using Blue Flapper on Drake/Ultramax toilet
    By tototalitarian in forum Toilet Forum discussions
    Last Post: 03-16-2008, 07:51 PM
  4. Toto Blue Flapper
    By dlrousseau in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2008, 08:45 AM
  5. Toto drake flapper
    By daxathon in forum Toilet Forum discussions
    Last Post: 08-10-2006, 07:44 AM
