Results 1 to 5 of 5
Thread: Ok to connect two SS flex supply lines?
    DIY Junior Member moose186's Avatar
    Nov 2010
    Midwest
    Default Ok to connect two SS flex supply lines?
    Is it safe/ok to make a 24" length of flex braided supply line using two 12" lines with a brass coupling? My supply valve is 22" from the faucet.
    Also, my tailpipe in the bath sink has rubber gaskets above and below the drain...should I be using plumbers putty too or is the rubber enough?
    Thx in advance!
    You can connect two braided supplies using the brass nipple.
    The lav drain uses the rubber gaskets. You can't use both putty and gaskets.
    On the veritical threads, some plumbers will use either putty or pipe dope. That's the part that slides through the lower gasket, large washer and nut.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    They make braided extentions for this with a 3/8" female x 3/8" male but either way will work.
    Either use the 3/8 x 3/8 male/female (the male end usually has a "coupling" on it for attaching to a copper line. If so, discard it), or a 3/8x3/8 female/female with a 3/8" compression coupling between them. It makes a neater installation.
    Nov 2010
    Midwest
    thanks everyone for the great help...
    after 3 months of weekend work and some weeknights, the bathroom is done and working and no leaks and life is calm again.
  1. clawfoot tub water supply - flex?
    By ChrisRice in forum Shower & bathtub Forum & Blog
    Last Post: 10-18-2013, 09:59 AM
  2. Compression va Flex Lines
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2010, 09:44 AM
  3. Flex lines - code?
    By dx in forum Water Heater Forum, Tanks
    Last Post: 10-27-2009, 02:20 PM
  4. Saddle Valve into flex water supply line?
    By kine97 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-30-2007, 09:02 PM
  5. Do I need a flexible copper fitting where these lines connect
    By templar2b1ask1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2005, 12:11 PM
