Results 1 to 9 of 9
Thread: deactivate buderus hot water tank
Hybrid View
    DIY Junior Member mtbmike's Avatar
    Oct 2010
    shrewsbury, ma
    Default deactivate buderus hot water tank
    Hi -
    i have a 6 year old buderus oil fired boiler with a buderus hot water heater installed under it.
    the hot water heater is broken and needs to be replaced. Warranty is not in effect because
    the anode rod has never been changed. I'm not interested in replacing with buderus. considered
    installing a superstor tank but price is holding me back.
    I plan to install and use an electric hot water tank, and to try that for a few
    years, maybe consider the superstor at that time.
    my question is, will the buderus continue to run the boiler attempting to heat
    water in the (now unused) hot water tank? What i mean is, presently the boiler
    fires up whenever the hot water in the tank is depleted or cools down to some
    preset temp. How can that be stopped?
    It may be as simple as removing the leads from the aquastat for the indirect. If you have the model number and the manual, if it is possible without changing the controller, it should be called out. Often, an indirect is just another zone, so if you remove the ability of it to call for heat, it should stop any burn.
    Oct 2010
    shrewsbury, ma
    thanks for explaining that. sounds logical that that's what i need to do. i do have the manuals (Buderus G115 cast iron hot water boiler) and the aquastat (Honeywell L8148A) wiring schematic is in there. By comparing to the boiler schematic
    i believe i can see the leads that need to be removed. i guess a little experimentation will tell!
    Oct 2010
    shrewsbury, ma
    Quote Originally Posted by mtbmike View Post
    ok, i have the honeywell i mentioned above, and it's connected to an Argo AR861 311 aquastat. the manual is here:
    http://www.ecrinternational.com/secu...ument/1546.pdf
    the circulator that contols my hot water is wired to terminals GZ2 and HZ2 on page 17. if i disconnect those
    leads, does that make the boiler stop heating hot water? thanks for helping out this newby...
    If someone that already knows doesn't answer, I'll look into it tonight. Got a few things that have to get done...
    Jan 2009
    At Worcester's fairly high (Nat'l Grid) electricity costs, are you sure you really want to buy an electric tank, suffer it's lousy first-hour rating limitations while paying extra to heat it (slowly) up, then throw it all away in a couple of years?
    Most (but not all) streets in Worcester are on the gas grid (NStar)- got gas? A bottom of the line gas tank heater would cost less to operate and deliver more HW than any electric tank in your (and my) utility environment, and will be be less than heating HW with the oil-fired Buderus too. We're at/under a buck/therm retail delivered price on gas, which would be the cost equivalent of $1.40 oil efficiencies all being equal. Summertime efficiency on the Buderus + Superstor would be somewhat less than a standalone gas-fired beast of a tank, but could edge it out during the heating season.
    Only if yours is a hot-water sipping lo-volume household would an electric tank make any sense financially or operationally, but, not if you're just going to junk it in short years for something else.
    Oct 2010
    shrewsbury, ma
    ok, sorry, i'm not in worcester, i'm next town over (shrewsbury). No gas on my street.
  1. Buderus GB142 and outdoor reset
    By jhetri01 in forum Boiler Forum
    Last Post: 05-28-2010, 07:11 AM
  2. Convert propane tank to water pressure tank
    By jhv in forum Irrigation / Sprinkler Forum
    Last Post: 06-27-2008, 08:23 PM
  3. buderus wall-hung won't fire
    By shenelec in forum HVAC Heating & Cooling
    Last Post: 11-25-2007, 11:15 AM
  4. odor from direct vent Buderus boiler
    By marsol in forum HVAC Heating & Cooling
    Last Post: 06-11-2007, 06:46 AM
  5. Indirect Hot Water Tank vs. Hot Water Storage Tank
    By Buckward in forum Shower & bathtub Forum & Blog
    Last Post: 01-27-2006, 09:30 AM
