Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Wire size for 120V water heater?
  1. #16
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by ballvalve View Post
    And I think the Indian-Indonesian anti-defamation league will soon be contacting you about that kid in a bowl about to be eaten by a snake.
    Some Germans sent me this pic. I'll pass the buck to them if the kid disappears and the snake has grown noticeably larger.
    Here's some bedtime reading
    http://www.illinoisconstructionlawbl...oes%201-18.pdf
  2. #17
    Dec 2009
    northfork, california
    Its a pity that a 10 gallon water heater costs more than a 50 gallon job.
    You can find a 20 gallon mobile home one for 250$ or look at motor home water heaters, and get a small 120 volt element, maybe 1200 or 1500 watts, and you could plug it in under the sink without more wiring. That would likely be cheaper than a recirc system, and you can super insulate the unit too.
    If you use a lot of water at that sink, your incoming cold could be the HOT in from the water heater. That should fill in the "lag" time
  3. #18
    Aug 2008
    MD
    You only have to make up 1 gallon of cold water per 100' of 1/2" ID pipe. It's ~800 BTU for a 90F rise, so using 1200 W it'd take ~11 minutes to recover.
    You probably have the whole morning to recover. A 120w heater will take 1.8 hours to recover.
    Decide on what tradeoffs you can make and then hope somebody makes a heater that does this.
    8.3 pounds/gal
    90 F rise
    747 =BTU
    according to
    http://www.onlineconversion.com/
    this many BTU per hour equals
    219 watts
    with 1200 w
    this takes
    0.1825 hour
    10.95 =minutes
  4. #19
    Dec 2009
    Right, so a 1200w or less 5 or 10 gallon WH under his sink, with the hot from normal heater as infeed would solve his issue pretty cheaply with less issues than recirc.
    Would also keep his undersink warm and dry, an advantage toward cabinet survival.
  5. #20
    Aug 2008
    MD
    Yes, I hope we find out how it finally worked out. The OP certainly has all the facts by now.
    Mr. Valve, you are definitely not a run-of-the-mill electrician.
    Good. You can make up for the [name deleted] types in this world.
  6. #21
    DIY Member Artie's Avatar
    Nov 2009
    Jacksonville, Fl
    I will definitely let everyone know what I finally decide on. I really appreciate all the info and ideas. I like the idea of feeding the small tank from the larger one.
  1. breaker size for 12 gauge wire
    By whoazone in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 05:02 PM
  2. Wire size question
    By jparrie in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 04:46 PM
  3. Intermixing wire size
    By Mr_Magoo in forum Electrical Forum discussion & Blog
    Last Post: 08-13-2008, 03:17 PM
  4. 240V electric water heater on 120v circuit
    By miscmail1560 in forum Electrical Forum discussion & Blog
    Last Post: 12-12-2007, 04:52 PM
  5. 1 pole, 2 wire or 2 pole 3 wire switch for water heater?
    By bigtime in forum Electrical Forum discussion & Blog
    Last Post: 11-04-2007, 05:13 PM
