I just brought home a brand name toilet that I had assumed was made in Wisconsin and was surprised as I removed the toilet bowl from the carton to inspect for damage. The under side of the bowl had three areas that had a porcelain like white-ish patch while the rest of the underside was unglazed. Two of the areas were on adjacent sides of the bottom of the round bowl part at the front and the third area was right in the center under where I guess the water jets into the trap area.
My question is.... could this be a normal manufacturing process or are all three areas patched to deal with defects or cracks in the clay ? The two areas under the bowl look like the clay may have been cracked and then covered with this white-ish stuff but the area under the water jet area is hard to understand..
I am concerned about a problem with these areas later after the one year guarantee ends..
Also the LITTLE sticker on the underside of the bowl said"crafted in china"
Does any one have any knowledge about this??? I am thinking about returning the toilet . It is a two piece toilet...
Thanks...
Thanks...
