Thread: Plastic Piece on inlet pipe
    DIY Member jdon88's Avatar
    Jul 2010
    Pottstown PA
    Default Plastic Piece on inlet pipe
    What is the purpose of the plastic piece with rubber disc inside the inlet and outlet pipes? This is on a new Bradford-White heater.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    They are check valves to stop hot water migration through the pipes. They can cause issues as they can get build up inside them and cause flow problems. You could remove them if ya like.
    DIY Junior Member Mike Monett's Avatar
    Jul 2011
    Ontario
    Quote Originally Posted by jdon88 View Post
    It might be a dielectric union to prevent corrosion due to galvanic current between dissimilar metals. Check this article for more information:
    "Using A Dielectric Union To Join Galvanized And Copper Water Supply Pipes"
    http://www.hammerzone.com/archives/p...n_de/intro.htm
    Mike Monett
    The disk means it is at a minimum, a heat trap. It may also be a dielectric union, depending on what it is made of. Make sure that they are used in the proper location (hot/cold) as if swapped, they'll tend to block flow when you turn on a valve.
  1. Plastic Pipe Insulators / Brackets thru Studs for Copper Pipe -- When Required?
    By speede541 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-11-2011, 10:44 PM
  2. Toto 1 Piece leaks from Plastic P-Trap
    By avellino in forum Plumbing Forum Discussion & Blog
    Last Post: 07-28-2010, 01:47 PM
  3. Inlet around well pipe into house leaking - how should I seal?
    By jdhanson1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2009, 05:12 PM
  4. Broken pipe piece
    By winnipeg@07 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-25-2008, 10:54 AM
  5. Filter - 3/4 pipe to 1" inlet better pressure?
    By brador in forum Plumbing Forum Discussion & Blog
    Last Post: 05-28-2008, 05:45 PM
