Thread: leak from top of fill valve?
    DIY Junior Member apac's Avatar
    Aug 2010
    athens ohio
    Default leak from top of fill valve?
    water is leaking from the top of that black thing. i highlighted in red the rod, right under which is where the water appears to be coming from. the toilet is flushing fine, but refilling takes 10minutes. wasnt like this before. it is also making a whistling type noise when refilling, but everything i read says that only happens with the old float ball design, and this toilet has a overflow valve
    Fluidmaster sells a replacment washer that may fix this. Sounds like you may have some debris caught inside. A new gasket washer is cheap, and worth trying.
    Aug 2010
    athens ohio
    so should i just buy a replacement top thing of the fill valve? i dont know what a gasketwasher is. i took off the black top thing and when i made it fill with water, it sprayed everywhere. and i did the watercolor in the tank test, no leaks if that means anything
    The gasket only costs a buck or so and is easy to replace. The instructions are on the card.
  1. Water use - hissing G-Max Korky 528 fill valve - Quiet Fill
    By urdrwho in forum Toilet Forum discussions
    Last Post: 09-23-2012, 04:15 PM
  2. Should I EXPECT fill valve to leak a little?
    By otherchuck in forum Toilet Forum discussions
    Last Post: 01-15-2010, 11:43 AM
  3. Toilet Valve Running with not Fill Valve Leaks?
    By tombstone in forum Toilet Forum discussions
    Last Post: 09-14-2009, 11:25 AM
  4. Toto Fill Valve Problem Continues G-Max valve with adjusting screw
    By levitonski in forum Toilet Forum discussions
    Last Post: 12-02-2008, 12:40 PM
  5. Tub Delta faucet leak - How to fill space at wall?
    By jdbs3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-16-2008, 04:23 PM
