Replace basement sewage ejector system
mz4wheeler
Replace basement sewage ejector system - FIXED!!
I have a house that is 30 years old, on a spectic system, and has a basement that is below the septic line. There is an existing sewage ejector system:
Mfg: Enpo Cornell
Model: 224
Type: 2
1/2HP
Symplex
The existing tank apprears to have been serviced many times and seems to be rusted. The top access cover doesn't seem to close properly because of rusty bolts. There also seems to be a fowl odor present that my wife can't stand. Basically, I want to replace the whole works.
It appears to be round, 24 inches in diameter, I can't tell it's depth, and SEEMS to be in a concrete casing. The top of the tank seems to be about 3 inches below the concrete line.
Questions:
1) How easy (or hard) will it be to replace the whole works?
2) There must be an input, can I remove the old tank without destroying the input lines?
3) Is it possible that JUST the top of tank is 24 inches, where the actual tank is smaller in diameter.
4) Will I be able to detach the input before I take out the tank?
5) Will I have to bust up concrete to take out the tank?
6) Can I unbolt the input from the inside of the tank
Regarding the replacement tank. Recommendations? Can I use a smaller diameter tank or do I have to have the same 24 inch diameter model.
--or-- Am I way over my head and I should just call a plumber [grin]
Mike
ejector
Questions:
DarkGreen]Probably hard
Yes, but read further.
The tank itself is 18" in diameter.
That is what has to be done, but the input is fastened to the tank from the outside. Keep reading.
Definitely. You have to get down to the inlet pipe and unfasten it. The degree of doing that will depend on what kind of connection was made.
NO!
That will be the smallest size you will find for a "proper" ejector tank.
Probably, but he might suggest just replacing the lid and verifying that all the connections to the lid are tight and sealed.
Mike[/QUOTE]
Master Plumber Mark
www.weilhammerplumbing.com
leave it be
dont fool with the thing....
all you got to do is buy yourself a new lid whhich
you can get a generic lid anywyere from any
plumbing outlet....
then all you got to do is install a new ZOELLER pump
and fit the pump to your new lid....
the bolts might be rusted up and all and they never work again..
we have to literally chizel off these bolts all the time........
but all you got to do is re-seal the lid down with 3-4 tubes of silicone
and youi are good to go... just lay it on thick
we run into this all the time and simply cannot make the bolts work
anymore, so you do what you got to do , to win the big battle
and clear silicone or siliconized caulk really works great to
completely seal all the smells into the pit....
I would do this first befoer you really make a god-awful mess
for yourself ....... which you dont want...
Honestly , I dont think any plumber in his right mind would
even attempt to do what you are thinking about...
so try thhis "less invasive" approach first.
mz4wheeler
[sigh].. This thing is 30 years old, so there is no way I could buy a replacement lid. Also, it looks as though there are no bolts around the edges. The bolts seems to form about a 12" oval shaped access plate.
All of the generic lids won't fit this thing. SInce I don't want to worry about this thing fro the next 30 years, it's better if I replace it now. The thing I fear is sewage leaking into the concrete casing, thern it will stink forever.
Thanks for the advice!
plumbing outlet....
Master Plumber Mark
good luck, your gonna need it
do what ever gives you the warm fuzzies....
I would personally call some plumbers out and ask their
opinions before you start breaking up that sewage pit....
because thats certanily going to be one hell of a nasty mess
breaking up a concrete pit that has been submerged and immulsified
in raw sewage for decades is not for the faint of heart....
when you break it up in pieces, it is literally going to splatter
everywhere and on everyone...
If I absolutely had to do that job, I would probably consider wearing a haz-mat suit to keep clean
why not just go swimming in a septic tank??
Remember, once you have damaged it , then you are gonna be
in it up to your eyebrows till the bitter , bitter end... and this could be
about as mean as any normal plumber would ever take on....
way , way , way above and beyond the call of duty......
you are not gonna find a lot of people willing to tackle
something this nasty --only the real dummies.
especially when really all you probably got to do is use
a little ingenuity and have a sheet metal man
make you a special pre-fabricated lid..... NO BIG DEAL
Dont start this project unless you are man enough to finish
it yourself, because once you have screwed it all up and
you need help, I doubt you will find many people willing to
come to yoru rescue and bail you out at a fair price....
then you are gonna pay through
the nose to find someone to get you out of the mess you
have made.... and you dont want that to happen either.......
I guarantee that you arent gonna get
me to do it...I am not that hungry
I would not even bid that job.
just remember the saying
"fools rush in where wize men fear to tread"
that saying certanly applies here,
So I would really think this through if I were you...
because you could have yourself over a month long event on your hands
with your wife jumping up and down about the smell and the mess....
getting a special lid made cant be that difficult and a couple tubes
of silicone to seal that down is cheap , cheap , cheap...
Respectfully, take the easy path first, if it dont work out good
then take the stupid one....
Dunbar Plumbing
www.KoldBreeze.com
Warm Fuzzies
I got them once working on a sewage ejector pump replacement. Dry skin on an elbow started it all when I elbowed down on what I thought was a clean surface which was my foam pad. Sewage must of splattered on it and the rest was a doctor's visit and a Rx for an infection. Unexpected but the warm fuzzies had me thinking about charging more for the next sewage pump replacement. :D
mz4wheeler
Hmmm... Well, all of this has be reconsidering the whole job [grin]... I've attached two photos of what I'm talking about.
A REAL plumber is coming over today to look at it. Hopefully he's one of those "beginners" [grin].
Mike
mz4wheeler
I put that "great stuff" on the top of the tank to seal some of the smell... And this really helped alot. But still............... [grin].
Master Plumber Mark
looks pretty mean
that looks pretty wicked to me.....
change the pump put a new lid on it and re-seal it
with the sealer of your choice
and just forget
any dreams of anyone doing that nasty job for you...
in my town that would be worth about
1000 just to change out the pump
and rig up a new lid to work . Some might even
be as high as 1500.
mz4wheeler
[Getting a little scared]... Are you suggesting that the sewage pit is just a concrete pit and with a metal lid? Can you tell from the photo if this is a metal tank? I assumed that it was.
When these things were installed 30 years ago did they just dig a big hole below the basement, put the tank in, and back fill concrete in all sides? There seems to be a small gap between the side of the tank and the concrete. if the tank was sank in the hole with concrete back-filled it may be real hard to remove.
From the photo you can see that the top of the tank appears to be about 3" below the concrete line, so it looks like the concete was pre-formed into a 24" circle, and the tank was lowered into it, or maybe not.
I can't seem to find any information about this particular tank. I'd sure like to get a spec sheet in the original tank so I can make a final decision.
Mfg: Enpo Cornell
Model: 224
Type: 2
1/2HP
Where can I get info on this?
I REALLY appreciate all this input, it's great to have expert opinions
Master Plumber Mark
leave sleeping smelly dogs lie.
who knows what its made of ....
probably plastic with a lid....
if its made of concrete its more of a commerical
type of unit and not to me messed with.....
its simply best to leave it alone and make repairs to it as
needed .....
you got to be nuts to fool with it either way....
just repair it for 1000 and forget about it.........
it will last you another 20-30 years ,
what more could you ask???
you are not going to serve dinner on it , right??
So as long as your wife cant smell it, forget about it.
I would not even attempt to tear that out
and if I absolutely HAD to give you a price, I would certanly
make it a very high one just to make it worth my pain and suffering.
and hopefully scare you into changeing your mind.
how about $6500
you could simply repair that unit 5+ times
or more for that kind of money.
mz4wheeler
Well, after receiving advice on this forum and a so-called "plumber" who visited my house and chickened out, I decided to tackle this job myself. I knew that it wouldn't be easy, and it took me a LONG time to finally decide once and for all to tackle this nasty job. A few considerations:
1) I was already in the process of remodeling the basement. Walls were already ripped apart, etc. I actually STOPPED working on the rest of the basement, pondering on what to do about this old, smelly ejector system.
2) I already "sealed" the septic ejector with "great stuff" foam, which did an excellent job of sealing *MOST* of the smell.
3) This is a "deam house" for myself and my wife, waterfront, 4300 square feet, and so far all the improvements I've done were first class. I'm trying to do things right, and not half-ass.
4) I didn't want to fork out $2000 (or so) to a plumber to a job (In MY mind) that I could accomplish myself, although my wife was EXTREMELY SCARED of me tackling this job myself.
5) It STILL smelled, even after I sealed it with that "great stuff" sealing foam.
6) I didn't want to be haunted 5 years later when the pump failed and I have to once again relive all these septic ejector issues.
PLANNING:
I knew that it would be a messy, smelly job, so I placed an exhaust fan in the bathroom window (the ejector is in the bathroom closet) that constantly blew OUT, minimizing smell. This worked PERFECTLY!
I knew that I would need to use a hand truck (to wheel out the pump and tank) and I would also need to use a wheel barrow, so I removed doors leading outside.
I also knew that the floor would be all messy, so I bought the 2 foot wide plastic rolls with sticky stuff on the bottom. I "protected" the carpet and floor with this sticky plastic, doubled, leading out of the house. This allowed me to make a mess of the floor, and not harm our NEW carpet in the house. I pictured in my mind this disgusting tank DRIPPING of sewage as I hand trucked it out of the house. It DID! And the plastic saved a big mess!
I also knew that I would have to somehow LIFT the old tank out, which was stuck in the mud for 30 years. I drilled holes in the rafters and attached a come-along hand hoist so I could lift the tank. This also worked.
I manually rigged the ejector motor and drained the tank as far as it could until I could hear the pump sputter. I then closed the gate valve to allow me to disconnect the pump. I knew that I would have to cut the ejector ABS piping about 40" high later so I could remove the tank so I bought a 2" cap
However, I really didn't know which direction the input to the tank was. Was the direction from the toilet (no problem) or from the shower. Or, (worse)were there multiple inputs? This was a problem because on one direction there was beautiful marble flooring, and I wasn't willing to destroy. After removing the tank lid (with the hoist) and hand trucking the old smelly pump out of the house, I saw what I wanted to see. A single input contained in the closet area. I also verified that the depth of the tank matched my new tank, and it inlet depth was roughly the same... 10 inches of so.
I was ready to go to phase 2. JACK HAMMERING!
This was a lonely feeling. I still haven't reached the point of no return... YET, but when we finally exposed the input pipes, I was able to see the SOURCE of the SMELL. Corroded INLETS!!! The sewage was mostly going into the tank, but some was LEACHING into the surrounding soil around the tank. No wonder the tank SMELLED!!!! After my father-in-law used a large crow bar and punched holes in the side of the tank to jar it loose... THATS when I knew I reached the POINT OF NO RETURN. There was no turning back now. Onward ho... etc.
Now there was a BIG problem. We couldn't remove the tank unless we somehow disconnected the inlet pipe. We tried, but it was impossible. After a couple of hours of futzing around, we took a small hand grinder and cut a slit in the metal couplings and a crow bar separated the inlet couplings (see photo). We were then able to disconnect the inlets... Finally.
We were now able to lift the tank out, but because we live on the water the watertable of the house was really high. The tank was locked into the soil/mud by suction. It was also heavy because as we were working on freeing the inlets, water was busy SEEPING into the tank.
This was the REAL NASTY PART. I had to empty the tank using a small bucket, face to face with the nasty, disgusting sludge 30 years in the making. Absolutely one of the most disgusting things I had to do in my life!!! My father-in-law wisely watched and smiled whilst I emptied the tank into an old plastic garbage can, and carefully hand-trucked it out of the house.
We were able to lift the tank only by allowing air into the bottom of the tank by punching a hole in the bottom. Once we did that the tank lifted out using the hoist.
Whew... That was the hard part. I've attached photos for your amusement and for anyone who wants to try this job themselves. It was a great feeling of satisfaction that I was able to do this job myself for about $400, which included renting the jack hammer for 4 hours ($50). Better yet, my wife and I are able to relax and know that the septic ejector system will be fine for the next 30 years w/o any worries.. Peace of mind, and finally no SMELL!
mz4wheeler
More photos
mz4wheeler
More photos. Thats it!
Mike
Dunbar Plumbing
www.KoldBreeze.com
Looks like you did a quality job for a fraction of the price of hiring it out. I will say you have a really nice lakefront property. I have to say......I do not think I would even tackle a job like that anymore; with me being 86 years old I think my body would just hop in the hole and need covering up. Spend about 10 bucks and install one of those battery operated alarms with the sensor prods that you can peel and stick to that lid on top; build a damn around it so that if the pump fails, it will let you know before it damages everything around it. Great Job! :)
mz4wheeler
Wow. Building a DAM is a great idea!!! I did some experimenting on what would happen if the motor failed. I unplugged it and flushed the toilet a few times. It eventually failed to flush and backed up at the toilet. The lid was fine.
However, if it failed while washing clothes, I believe that it wouldn't fail so gently. It probably would fill up the air vent and probably leak out the edge of the tank. It may even seep out the toilet? It is probably a good idea to completely seal the tank seams, build a concrete dam and rig up an alarm.
Thanks for the compliment on the waterfront. My wife and I love it, although we've been challenged a few times with issues of the house (roof, concrete, septic ejector, etc). It really keeps me busy!
bobbg53
Missouri
Mike
has this held up at this point 11 years later?
I had problems with mine before you did but now its so bad I need to do what you did.
Only I changed some pipes in my house so the kitchen sink no longer drained into it, and only water from the basement floor drain did. so its not as smelly as your was.
The plastic tank is falling apart the bottom has broken out of it. the motor stopped working about 15 years ago right after we bought the house. I never replaced it the only water going is was from the HVAC system and any water the floor drain had, We have never used the John in the basement the house was 7 years old when we bought it. and the systems had gallons of bleach dumped into it several times. If it got to full I'd vacume it out with a wet-vac and dump the clear water outside. Now the tank is broken, and I've got a new pump for my kids house I' never installed I'm going to have to deal with it and tear out the tank and install the new tank and pump. I didn't want to bust up the concrete and I think It could be done without doing that.
Any comments? I was going to cut the inlet PVC Pipe add a coupling outside where the tank would be drop in the tank line up to the inlet and fit a new inlet through the flange to the coupling and glue it this seals both the flange and the coupling into one. And I won't have to rent a jackhammer. I'll try a dry-fit before adding cement.
