casing cutter
konk
colo
Guys need to cut 5'' pvc 5' down and remove, is there a tool i can buy or make to do this? Thanks Dave have to cut from inside
konk
colo
NO the backhoe would cost to much. The pvc is inside surface casing, but thanks for the reply
Ballvalve
northfork, california
how about a small sawblade on a 5' arbor with a drill. have to make it...
do it thru a hole in a board set on the casing so the drill doesnt hop around. hold it down and ride the chuck on the plate.
...why are you doing this?
be sure it all does not drop in the hole.
Masterpumpman
Virginia Beach, VA
www.dci-inc.us
There is a special tool made to cut PVC Well casing from the inside but it is expensive. Most drillers do not have one.
If it's a must do I suggest that you contact Chuck Mills @ Mills Machine Company, P.O. Box 1514, Shawnee, OK 74802-1514, Tel: (405) 273-4900. Chuck may have one to rent.
konk
colo
Thanks, know about the drill setup doesent wroke so good. I have used a die grinder set into a 3'' pvc pipe and lowerd down 5' to cut it off. I just wonderd if someone had a better setup. Cutting the pvc out so the pump setter can put pittles on. we have steel surface casing, Thanks
