Results 1 to 6 of 6
Thread: DIY dishwasher install to double sink
    DIY Junior Member renomama's Avatar
    Jul 2010
    NY
    Default DIY dishwasher install to double sink
    My friend says this will work, is he right? I'm afraid I'm going to have backup. If it's not right what will work better?
    Thank you
    That is wrong, wrong, wrong.
    Cut the tailpiece on the left and have the p-trap grade downhill to the sink drain.
    The first ruile of plumbing, is that water needs to go downhill.
    Are those soap bubbles on the rubber connector, too? It isn't sealed well. As plumbed, the drain line (trap arm) will fill up with food particles and crud, and block up. It has to flow downhill from the output of the trap.
    Actually, there is no good way to connect whichever side gets the dishwasher. I would use two "P" traps on that installation, but the "branch tee" is still going to make that one hard to connect properly.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    basically you need to cut the wall open and lower the san tee in the wall ! !
    Drainage water " does " not run uphill you have to get that lower in the wall that is
    all there is to it !
    Once you do that the rest of the sink plumbing will come together the right way ! !
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    There are three inviolable cardinal rules of plumbing.
    1st rule: things flow downhill. You have created worse than a deep trap, which is a problem in itself. You have a serious crud catcher.
  1. How to install dishwasher drain to double sink?
    By TCiura in forum Plumbing Forum Discussion & Blog
    Last Post: 10-26-2012, 08:21 PM
  2. No hot water in kitchen sink after dishwasher install
    By bullseye in forum Plumbing Forum Discussion & Blog
    Last Post: 10-27-2010, 02:46 PM
  3. install garbage disposal in double sink
    By homey6660 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-06-2009, 07:35 AM
  4. Another double check re: ceramic floor tile install
    By DIY in forum Remodel Forum & Blog
    Last Post: 05-19-2007, 07:45 AM
  5. Converting Double sink vanity to single sink
    By karenwondergem in forum Plumbing Forum Discussion & Blog
    Last Post: 05-31-2006, 06:17 AM
