Thread: retrofit weeping tile
    DIY Junior Member tjetson's Avatar
    Oct 2009
    winnipeg
    Default retrofit weeping tile
    Hi,
    when installing weeping tile on an existing basement, Footing with concrete wall. do you run the weeping tile under the footing ? or drill threw the footing? It seems to me the smarter choice would be running it under the footing but then you will be very low to the sump pump
    please let me know what is the best practices
    thanks
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    Smile
    I have used the following method on several retrofit homers with 100% success of:
    Don’t drill through the footings or wall !
    • Break out concrete basement floor approximately 18 " from the outside walls.
    • Dig out a trench to the bottom of your footing. (Below floor, 1' to 2' deep)
    • On the very first course of block, drill a series of Ύ" hole into each block cavity releasing any trapped water from within the block.
    • Install drainage board in front of drilled holes from the weeping tile trench up wall to just below the bottom of the floor.
    • Place 4" weeping tile (Fabric covered) beside your footing.
    • Inside weeping tile can now be hooked up to sump box or closest floor drain.
    • Excavated area should be covered with Ύ" gravel to just below floor level
    • Re-pour concrete floor leaving Ύ gap space at wall
    Success !
    A lot of work but well worth it. I never did understand why builders just did not put weeping tile and proper exterior sealing and drainage board on foundations.
    Do not drill holes into a poured concrete wall.
    • To install an inside weeping tile system for a poured concrete foundation, the process is the same.
    • Drainage board will allow any water, that has gained entry, to freely drain into new weeping tile system..
    Dont's:
    1. Again, do not drill holes into a poured concrete wall or footings !
    2. Do not dig deeper than the bottom of your footing.
    Kevin
    You can go under the footing and then back up to the pit's location if necessary. It just creates a "trap" in the line that the water can pass through. NEVER, NEVER drill the footing. It has "rebar" in it to stabilize the concrete and if you cut it, which you would have to do, it would severely weaken the building's structure.
  1. Minor weeping leaks - are those OK?
    By alexgav in forum Irrigation / Sprinkler Forum
    Last Post: 08-06-2008, 11:52 PM
  2. Compression Fitting Weeping Solution
    By Wrex in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2008, 07:53 AM
  3. Retrofit and Air Gap
    By wlam08 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-01-2007, 03:08 AM
  4. old weeping bed
    By muffy in forum Toilet Forum discussions
    Last Post: 03-15-2007, 09:50 AM
  5. Weeping Memoirs
    By Mike50 in forum Toilet Forum discussions
    Last Post: 02-06-2006, 09:39 AM
