Results 1 to 5 of 5
Thread: supply temp ver: return temp
Hybrid View
    DIY Member rrekih's Avatar
    Oct 2009
    Canada
    Default supply temp ver: return temp
    I have a small staple up under floor radiant heating system.
    Right now 8 zone manifold that I am using 5 zones, will be adding 3 more zones in the near future.
    I am running supply temp of 140deg F (it actually runs at 137 / 138deg F)
    The return temp is between 126 and 128deg F, so it runs between 8 to 10deg F cooler.
    Is this a good ratio?
    Thanks for any info.
    If the zones were too large, the return temperature would be much lower and the "end" of the system would be starved of heat. You seem okay, but even if it were not a "good ratio", what could you do about it now?
    Oct 2009
    Canada
    It is not a finished area at the moment so I could in worst case scenario do a reconfigure.
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    A tight Delta T on radiant flooring can be a good thing, offering even temps however, tight S & R temps on the boiler depending on piping can lead to reduced efficiencies.
    Oct 2009
    Canada
    I am using a total modulating tank less hot water heater.
