Results 1 to 11 of 11
Thread: How to insulate the exterior walls under a 3 season room.
    DIY Member Rughead's Avatar
    Scarsdale, NY
    Default How to insulate the exterior walls under a 3 season room.
    Hi there. In Scarsdale, NY we've recently had our backyard deck, which was attached to the rear of the house, removed and 3 season "Florida" room built there. They did a good job and we're pleased with the new room, lots of windows, cathedral ceiling and well insulated. We'd now like to use the space underneath this room as a storage area for bicycles, gas grill, etc. but want to keep it as dry as possible. At present there is only a lattice type facade around the 3 sides which we'd like to keep for the look. Can I simply attach some XPS to this, from the floor of the room above to the gravel covered ground below, and then face it inside with plywood leaving a gap at the bottom so there's no contact with the gravel? The space will not be heated and we plan to leave the gravel floor as is. Look forward to any advice. Cheers and best regards, Rughead.
    In the trades Dana's Avatar
    Jan 2009
    XPS is rated for ground contact, but must be covered with an interior-side thermal-barrier such as half-inch wallboard or plywood to meet fire codes.
    The other issue will be ground moisture. Burying a a sheet of 6-mil poly in the dirt under the gravel works (it must be protected from puncture to STAY working. Sloping it away from the foundation is also a good idea, should it ever get bulk-incursions of water. If you don't put in ground vapor retarders when you seal & insulate the walls, in Westchester the mold & mildew season in that space would be 8-9 months out of the year!
    To do it at least half-right would involve a poly vapor retarder under a rat-slab (non-structural thin concrete slab that keeps varmints from burrowing in to the now-cozy & dry shed-room), with at least 2" of XPS on the exterior behind the lattice with at least 1/2" ply on the interior through-screwed to the structural members. Use duct-mastic to seal the vapor retarder to the XPS before putting up the plywood,and at where it meets the exterior if the house. Air-seal with spray foam or cobble'n'cut XPS foam-sealed at the edges & seams any of the gaps at the top of the wall to block thermal bypasses of air through the joists, and use a reasonably weatherstripped door or hatch as access. Rat slabs don't take a lot of concrete- an inch or stwo will do, and it'll protect the ground vapor retarder from puncture. For small rooms this is an afternoon of hand-mixing the concrete in a wheelbarrow, slopping it in there, and floating it roughly level. If it's over a hundred square feet do the math, and after you've already placed & sealed the XPS & ground vapor retarder order up the necessary cubic yardage for a 2" slab and have it delivered.
    Scarsdale, NY
    Thanks Dana. Am glad you replied as I've been following this forum for some time and you seem quite knowledgeable when it comes to insulation and vapor barriers, etc. Just a bit of clarity if you don't mind. From your above, I should put the 2" XPS directly on the lattice, then a 6-mil vapor retarder (sealed), then the plywood through screwed to the vertical structural members, correct? I like the "rat-slab" idea too. Should this be done before or after the walls? I could embed the XPS into the perimenter of the rat-slab couldn't I ? At present the "floor" under the room is dug out about 3 or 4 inches, then geo-textile fabric and then 3 or 4 inches of gravel. From your advice I assume I should remove the gravel and geo-tex, then put down the new 6 mil poly vapor retarder and then the 2" concrete rat-slab. Can I re-use some of the gravel with the concrete or would it be over-kill? BTW the floor space is 12'x 14', the size of the floor of the Florida room. Looks like a few days of hard work over my summer home leave. Again thanks for your advice and I look forward to anything further. Cheers and best regards, Rughead.
    Jan 2009
    Quote Originally Posted by Rughead View Post
    The XPS is best applied to something with structure to it- the lattice itself may not be rigid enough- it may need at least a header & footer board to glue & screw it to, as well as whatever posts are holding up the lattice. Dual or triple layers of 1" 4x8' or 4x9' XPS sheathing willl be better able to span between structural elements than the 2" 2x8' or 2x10' t&g stuff, so you may find a way to make it reasonably easy to span between structural elements on the exterior layer. Lapping the layers & bonding them with -sized blobs of foam board cement on an 18" grid between the layers, will make the foam much less flexy for when you put the plywood up. Then, walnut-sized blobs on a similar grid between the plywood & foam gives the final assembly substantial structural rigidity. The plywood still needs to be through-screwed to the structural framing to make it code-legal as a thermal barrier though.
    You don't need a poly vapor retarder on the XPS, but DO seal the vapor retarder on the ground to the XPS: Apply a bead of foam-board adhesive or caulk applied to the XPS, then staple the poly to the XPS with 1/2" or longer staples, then apply 1/8-1/4" of duct mastic (paintbrush or putty knife over that to seal the edge completely. (You don't want ground moisture finding it's way up to rot the plywood at the transition line.)
    Yes, pull out the gravel, but you can put the poly on top of the geo-tex, then seal it to the XPS before putting up the plywood. The rat slab can poured after the plywood goes in, and should come up to at least an inch below the plywood unless you're planning to put up wooden kick board after the rat slab is set.
    If you're mixing it yourself you can re-use the gravel as aggretate in the concrete. If it's crushed rock rather than rifer-rock/screenings it has some potential for penetrating the poly during installation, but the risk isn't high. A higher ratio of aggregate to portland cement also weakens the concrete, but it's a non-strucural slab- it's OK for it not to meet any floor-loading standard- it just has to hang together enough to keep rats, squirrels raccoons, skunks, possums, etc from digging their way in.
    While the ply on the inside may be sufficient for fire codes, the lattice on the outside might not be. You may need some sheathing on each side.
    Jan 2009
    That's a reasonble thought, but SFAIK there's nothing in the IBC about exterior thermal barriers, and as a point of common-practice vinyl siding, etc is applied over foam sheathing without any form of thermal barrier all the time. (Then there's the foam-insulated vinyl clad siding, etc.) Were it me, I'd put something up there to keep the pink or blue foam from shining through the lattice, but it need not be a fire-rated thermal barrier. If it's a place where it might get a lot of rainsplash some sort or rain-proofing like 15# felt or housewrap wouldn't hurt, but it's not critical.
    Scarsdale, NY
    Thanks guys. Shouldn't be much rain-splash but I don't want the pink or blue to be seen thru the lattice either. I'll look for a non-shiny brown roll of something waterproof (felt or housewrap) and staple it to the backside of the lattice before fixing the XPS to it. I'm not there right now but if my (61 yrs old) memory serves me well, I'll need to reinforce the lattice before affixing the XPS to it (as Dana pointed out) because it's a bit flimsy. I'm assuming it's ok if there's a 1" or 2" gap between the lattice and the XPS caused by the additional structural reinforcement. (Give the squirrels a place to hide their nuts and the hornets to make their nests, ha ha.) I will also check with the village if there are any code issues here. There may well be as the village inspectors are, at best somewhat knowledgeable, always pedantic, but usually just a p.i.t.a.
    I'll throw some of the crushed stone grey gravel into the concrete just for the volume so I can lay about 2" down as a rat slab. I'll leave the geo-tex in place. I might reinforce the slab with some cheap(?) metal grid as we'll be putting the gas grill in there, bikes, mower, etc. Or is that over-kill? We'll only be going in and out of there as the space is only 4.5 ft high... I'll be sure to seal the XPS to the vapor retarder before pouring the slab, but wait to put up the plywood 'til the slab is cured to ensure there's no contact. That's about it for now. Many thanks for all this good advice. Will report back when I get started while on home leave in July/August. Cheers and best regards, Rug.
    Jan 2009
    Reinforcing a rat-slab is a bit overkill. The floor loading of a gas grill or lawn mower is static and quite low compared to hot water heaters and boilers, etc. and even if it develops cracks over time due to loading so what? It still keeps the poly protected, and the critters out. (The slab in my 1920s basement is only ~1.5" thick and has fairly few cracks despite far more substantial loads than a gas grill.)
    But if you have a roll of pig-wire fencing rusting away in the back yard, it probably does more good in the slab than as a trellis for supporting weeds, eh? :-)
    Scarsdale, NY
    Gosh damn Dana, what're you doin up at 4 am? It's 10:40 pm here in Budapest. Thanks for your advice. Won't bother buying any reinforcement for the rat slab and just "get er done". Cheers, Rug.
    Nov 2009
    VA
    I think you are adding the time difference instead of subtracting. Dana's last post was at 2:44PM (EDT).
    Scarsdale, NY
    Could well be Nukeman. I was simply looking at the time as shown at the top of his post. I do know that I am 6 hours ahead of EDT/NY time. It's 4:10 pm here in Budapest. Cheers.
