Results 1 to 8 of 8
Thread: Wax Ring w/ bell/flange
    DIY Junior Member amat_plumb's Avatar
    Apr 2010
    CANADA
    Default Wax Ring w/ bell/flange
    I like to use wax rings that have the plastic funnel/flange/bell built into them. Seem to provide a more straightforward installation.
    Will using one of these compromise the flushing power of a Toto toilet? -which I plan on buying soon
    The outlet of the Toto trayway is 2-1/8"
    The inner horn of the wax ring is larger then that.
    Apr 2010
    CANADA
    arent there Totos with 3" trapways??
    Apr 2010
    CANADA
    and where/how can I buy one anyway
    in the GTA area , Ontario, Canada??
    Do not use wax rings with bell flanges. They frequently cause problems and are totally unnecessary.
    No.
    Toto makes toilets with 3" flush valves.
    That's the part that the flapper attaches to, and goes between tank and bowl.
    The only toilet with a 3" trapway is made in Australia by Caroma.
    They can't use a siphon on the flush, the trap is too large.
    They need to use a "wash down" flush.
    A trap larger then 2-1/8" is very hard to siphon.
    That's why the Caroma uses washdown.
    Toto Drake with siphon jet flush.
    The flush valve from the tank to the bowl is 3"
    The outlet of the trap is 2-1/8"
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    Quote Originally Posted by amat_plumb View Post
    Dupont Plumbing Supply, or Bath In Style carry Toto or any designer type fixture store.
    Feb 2005
    Omaha, NE
    Terry - your explanation really helps. The siphon jet design explains why I have noticed my Toto Ultramax II seems to "suck" waste out of the bowl, like a commercial airplane's toilet, rather than "push" it down like a washdown toilet. I never realized that difference before.
    The Toto 3" flush valve/2 1/8" trap design works GREAT. Can handle just about anything a human can produce without hiccuping.
