Results 1 to 6 of 6
Thread: New Reverse Osmosis tank
    DIY Junior Member tuffy's Avatar
    Feb 2010
    British Columbia
    Default New Reverse Osmosis tank
    I need to replace a 14 gallon RO tank. Which tanks are best to get long life from it.
    Dec 2009
    Alaska
    There are some from RO Mate that if you are looking for long life that would work. Also with the RO Mate can have the main part replaced if needed down the line.
    Did that 15 years ago at a company that I was working for.. 20 minutes and 95.00 later that tank was fixed and back on line again.
    RO Mate is not cheap, but very long lasting.
    or look for a plastic pressure tank and not the metal tank.
    Feb 2010
    British Columbia
    thanks Akpsdvan, do the RO Mate tanks use a better quality bladder? does it make a difference for plastic/fiberglass better than metal if the water is only in the bladder? Thanks for any insight anbody has in this matter
    Dec 2009
    Alaska
    Quote Originally Posted by tuffy View Post
    Metal if Moisture is on the out side will find any crack in the paint over time and start the rust... the metal tank has a rubber disc that is for the most part welded in to the metal,, thus will get holes in that part and let water in to the air part of the tank.
    When the ro mate or well mate pressure tank needs the replacement of the air cell it is simple and easy..
    http://www.wellmate.com/pdf/Commeric...structions.pdf
    Feb 2010
    British Columbia
    thanks akpsdvan
    Dec 2009
    Alaska
    As Garfield would say...
    No Problemo..
  1. New RO, Reverse osmosis
    By water solutions in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-21-2012, 12:50 PM
  2. Reverse osmosis - tank pressure?
    By jpb116 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2011, 11:14 AM
  3. Reverse Osmosis noisy
    By vegashomes in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-19-2010, 09:07 AM
  4. reverse osmosis drain help
    By mini bike man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-03-2006, 06:19 PM
  5. Reverse Osmosis or not
    By Kai in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2005, 09:58 AM
