Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Looking for comments on bottle traps
    DIY Junior Member Scott Vroom's Avatar
    Feb 2010
    Mountain View, CA
    Default Looking for comments on bottle traps
    I'm thinking about using either a Mountain MT2000 or Kohler K-9035 bottle trap drain beneath my vessel sink. Any comments on how well these work vs a traditional J-trap? The drain will be exposed and I like the sleek look of the bottle traps.
    Thanks-
    Scott Vroom
    Bottle trap
    Codes place certain restrictions on the construction of bottle traps, but any that you see for sale probably comply. I would check the product for some kind of approval such as UPC, IAPMO, CSA, etc. Without such approval, that is a de facto ban under most codes, and also local inspectors may have their own rules.
    I have never seen one in use, so I hope others can chime in here about how a bottle trap actually performs in service.
    ALL bottle traps depend on an interior baffle to create the trap. This does several things;
    1. It restricts the flow of water throught the trap, which is a violation of the codes.
    2. They are NOT self cleaning/scouring, which is a violation of the codes.
    3. The baffle is not visible so there is no way to tell it it has failed or not, which is a violation of the codes.
    4. Just because something is for sale, does NOT make it code compliant.
    5. And finally, they are not "adjustable" so the drain opening MUST be directly behind the sink drain's location
    Feb 2010
    Mountain View, CA
    HJ, you bring up some excellent points to consider. I'll check the local codes (Palo Alto, CA) to see if bottle dranis are allowed. The supplier said the 2 models mentioned are "compliant". I'll find out what that means. I'm guessing the concern with the invisable baffle is that it could fail thereby rendering the trap function useless, allowing gasses to enter the bathroom through the unprotectted drain. Is this correct? The lack of adjustability is a concern, however I'm installing a custom teak table for the vessel and had planned to drill the vessel drain hole precisely on center with the wall drain rough out.
    I'm beginning to think the bottle drain may not be a good idea and will begin searching for a high-quality brass/chrome P-trap assembly. Any brand/model suggestions are appreciated. Whatever I put in will be highly visable and must be high-quality and attractive.
    Scott
    Journeyman/Inspector Inspektor Ludwig's Avatar
    May 2006
    In the good ol' UPC
    One thing to watch out for is when someone says that the product is "compliant". Some products like bottle traps are not allowed by code but then you're always told that if it has the UPC or Iapmo mark then it's approved for use. The methodology just didn't make sense, why would the code forbid something then put their label on it? I took the model number of a bottle trap that a customer wanted to install because it had a upc symbol on it and looked it up on the Iapmo website for the listing. What I've found is that a product that has the listing mark on it has been approved but only some small part of the overall product, for example the bottle trap that clearly had the UPC mark was only approved for they type of material that the trap was made out of, not the style of trap. I called Iapmo to figure this out, the lady said that a bottle trap may have an approved listing for materials but the make and model number for the type of trap may not be approved, which was the case. The bottle trap being sold as a trap was not approved for a trap but the metal that it was made out of was an approved material so the manufacturers of the products put the UPC symbol on them. I've found that there are numerous products that have the UPC symbol that do not have a listing, a falsified listing or an incomplete listing. Alot of products are from China but I've also found products from Kohler and Grohe that don't comply either.
    You are in California, and the California Plumbing Code says this: ( 1004.0): No trap that has concealed interior partitions, EXCEPT THOSE OF GLASS, PLASTIC, or similar corrosion resisting material, shall be used.
    The code further says this ( 301.1) All pipe, pipe fittings, traps, fixtures, material and devices used in a plumbing system shall be listed or labeled by a listing agency.... and ..all materials, fixtures, or devices used or entering into the construction of plumbing systems shall be submitted to the Authority Having Jurisdiction for approval.
    That last sentence means a local AHJ ( your city ) may further restrict plumbing installations even if otherwise compliant with state code. That provision is what is still keeping PEX out of a lot of cities in CA, even though the state code allows it.
    It is sort of like import appliances having a UL approval lable, but it only applies to a portion of it, such as the power cord.
    Previous member
    Jul 2009
    North of the Mason dixon Line
    I would make you tear it out here.
    Feb 2010
    Mountain View, CA
    Quote Originally Posted by Peter Griffin View Post
    OK, but would you mind telling me why you would tear it out?
    Feb 2010
    Mountain View, CA
    I was looking at a Mountain Plumbling MT1000 bottle trap in the local plumbing supply store several days ago. I opened it up and it clearly had a plastic interior partition tube. Based on what you are saying this particular model would be code compliant.
    Previous member
    Jul 2009
    Because the IPC does not allow them. they are pretty much a drum trap. They are not self scouring.
    They would be "code compliant" until the plastic baffle came loose. Ask to see where the "IAMPMO" and other certification approvals/seals are on it.
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Bottle Traps
    Is the design of a Bottle Trap any more or less *reliable* than a P trap under a lavatory sink.
    Just looking at P traps as the sink will be exposed...and came across the bottle trap designs as well.
    The problem you will have with a bottle trap, is that is must perfectly center up to the lav.
    Most traps have a 4" swing, which means there is an 8" range that the trap arm can be plumbed to, and still hit the sink or lav drain.
    Install a bottle trap, and the lav hole "must" be cut to the drain location, not to the cabinet layout.
    I prefer to center a lav on the wall space, or to the cabinet layout.
    If you only have the bottle trap, the odds that it's in the right location is slim to none.
    But homeowner's will figure that out soon enough.
    Jun 2006
    Thx for the thread redirect Terry.
    Not self scouring..and limited to no tolerances in install.
    I'll think I'll stick to J traps.
    For all you plumbers out there, what variants do you like.
    I have used 2 Kohler Chrome J traps in exposed environments in the past and the brass was heavy gauge, and chrome finish was of good quality *not thin*
    Drain Surgeons - is there a preferred brand of J trap (chrome, etc) you may possibly recommend for expossed installs.
