Results 1 to 5 of 5
Thread: water is silty since new submerged pump was installed
    DIY Junior Member
    Jan 2010
    Mooresville, N. C.
    Default water is silty since new submerged pump was installed
    Since installing a new submerged water pump, my water has been silty. The guy that installed the pump said to 'bleach' the system and it would fix it. It didn't. Is it feasiable to 'stir up' the silt and run it out with all the outside spigots open?
    Moderator valveman's Avatar
    Mar 2006
    I would just try to pump it out for a while, using as many spigots as you can at one time.
    I wouldn't run a lot of water into a septic system.
    DIY Member JoshRountree's Avatar
    Nov 2009
    Fleetwood, NC
    I had to install a sediment filter when my pump was pulled last, and several others in my area have them too.
    Dec 2009
    Alaska
    Was the pump set lower in the well?
    Even a foot or two could be the difference.
