I'm trying to clean up the original and patched work done under my sink (90year old house). My wall stub out is approx 22 in off of the floor( with bad threads so I'm using a rubber sleeve). My disposer in on a 9" deep sink Thwe other side is 10.5 " deep. I have always got a little water up the other sink drain only when the disposer was full of water and I turned it on. The water is not too bad, it's the smell that I don't like in my kitchen. The T on the disposer is definately a diverter T. The Wall Stub is behind the disposal at about the same height as the discharge. The clear tubing is the dishwasher drain. The black tibing is connected from the disposer to the air gap. Do I need to lower the wall drain, move the disposer to the other side, I really don't want to loose my disposer. Any help will be appreciated. I'm also having problems with the fittings on the white trap leaking a little bit.
