Results 1 to 5 of 5
Thread: city supply line into hydronic system
    DIY Member rrekih's Avatar
    Oct 2009
    Canada
    Default city supply line into hydronic system
    When after filling the hydronic heating system do you need to have the city supply turned on into the system?
    Does the system use water and need refilling?
    If you have a leak wouldn't it be better to let the system run down and shut down the system?
    Jun 2009
    Penticton, BC
    Quote Originally Posted by rrekih View Post
    Yes you need to always have pressure in the system (12-17# cold). You need to install a boiler feed to maintain a constant pressure.
    You don't want to let the water pressure drop to 0 because you're always going to have SOME evaporation in the system.
    DIY Member msgale's Avatar
    Sep 2006
    there a 2 schools of thought on this:
    if you automatically refill your system, the homeowner may have a leak and it could remain undetected, with replacement water( with its own oxygen supply,which is bad) taking care of keeping sysyem filled.
    if no auto refill,then a leak means your system pressure drops, and eventually the homeowner is aware there is a defect
    Sep 2006
    normally a normal system loses a tiny amount of water, which you refill maybe once a month or so. if there is a leak, i think you are better off knowing about it.
    otherwise a hidden leak could go on forever, with automatic refill ,and rot your joists etc,
    Jun 2009
    Penticton, BC
    Quote Originally Posted by msgale View Post
    You could argue it either way really. But you were worried about it I'd suggest the person install an automatic fluid feeder.
