DavidTu
Running 1" PE tubing into a foundation wall below grade, through a 1-1/2" ABS sleeve... what is best way to seal the PE-ABS gap/joint and the ABS to concrete connection? Haven't found a caulk that says it can be used below grade for foundation wall.
I've been thinking to use GE Silicone II for the PE-ABS gap/joint... any thoughts? What do you all recommend for that and what do you recommend for the ABS-concrete connection?
NOTE: the ABS sleeve protrudes from the wall on the outside by several inches...so it is not all one connection/joint.
