Annap_mike
- Messages
- 24
- Reaction score
- 0
- Points
- 0
We have lived in this house since 2001. The well water has easily been the biggest cause of headaches and frustration... not to mention money spent.
New pump, tanks, filters, whole house iron and sediement filters, cleaning out the pipes from the pump to the whole house filter. But regardless it seems that every two years we end up having low water flow issues. The pressure is fine. You turn a faucet on and it will run with good water pressure for a couple of seconds but then the flow slows dramatically. The washing machine takes forever to fill up etc...
Is there anything that we can simply pour into the well that can run through the pipes and unclog the iron and sediment buildup that I am convinced is causing this flow problem. It is obviously built up and causing the water to run slow somewhere from the well to the water conditioner system in our laundry room.
If there is such a compound will it harm the iron and sediment whole house water filters.
What other options are there?
Thanks.
Mike
Thanks.
Mike
