Results 1 to 6 of 6
Thread: Where should I place a baseboard radiator in my bathroom?
    DIY Junior Member
    Nov 2009
    Indiana
    Default Where should I place a baseboard radiator in my bathroom?
    The room is about 50 square feet. Right now there's a 5 foot radiator in front of the window, but we're taking that out to put a bathtub in. Can we just move the existing radiator to in front of the bathtub?
    Web Development | HVAC patsfan78's Avatar
    Jun 2009
    Maine
    Its always encouraged to place baseboard, radiator or whatever on an outside wall. If that is not possible then install it where you have room but if you haven't purchased the radiator yet, you may want to consider oversizing it just a bit. But the outside wall is preferred.
    Mike
    HiTech Heat, LLC
    www.HiTechHeat.com
    DIY Junior Member
    Nov 2009
    Indiana
    Thanks Michael. The only outside wall in that room is where the tub will go. That's why I was wondering if it would be best to put it in front of the tub, or just not worry about being in front of that wall. The only other solution is to put in 2 - 2 ft sections.
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    What about electric radiant floor heat?
    That's what I did
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
    Jun 2009
    Penticton, BC
    In a 50 sq ft room you can place the radiator on any wall and it will heat the room up.
    I wouldn't put it in the front of the tub. I would do the 2 sections first and also, what about adding a ceiling heat lamp fixture? Mine has a heat lamp and an exhaust fan in it. Works nicely. If you do the ceiling an make sure it directly doesn't vent into the attic or you could get moisture & mold.
