Results 1 to 7 of 7
Thread: 4 inch riser clamp
    DIY Senior Member rockycmt's Avatar
    Nov 2007
    New York
    Default 4 inch riser clamp
    I am cutting out some cast in my basement. I want to reinforce the riser to the first floor. I went to ********* and the riser clamp they have needs to go above the subfloor. I want to support from the bottom. Do they make a riser clamp that screws into the floor above.
    thanks In adv,
    Default clamp
    You put the clamp around the pipe, then use bolts in the space between the arms on either side.
    You want the anchors to be in shear rather than in tension. On the building where I work, they just let the arms of the clamp sit on the concrete floor around the hole.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Can you support from above and recess in to the floor?
    You could find some type of angle bracket to attach to the riser clamp that can then be attached to the floor.
    General Contractor Carpenter toolaholic's Avatar
    Jul 2005
    Marin Co. Ca.
    Question It's just like You
    Would You like Your whole body weight supported by Your feet, or do You prefer to hang by Your ears? I'M BACK!
    Aug 2005
    Columbus, OH
    Quote Originally Posted by toolaholic View Post
    FWIW, when I was little my sister used to come up behind my and squeeze her hands around my head over my ears and pick me up.
    Jul 2005
    Marin Co. Ca.
    She needs a spanking ! No, I'm Married
