Forty-Two
We've developed a leak in a most inconvenient spot, and I am looking for advice on what to do. Okay, it's not buried in concrete, so I have that going for me!
I've attached a picture of the offending ABS stack. It's an honest-to-goodness crack in the fitting, not a joint leak - not that it matters. I guess this means there was inappropriate pressure on this thing at some point.
What is hidden behind the dryer vent is the horizontal run this stack drains into. There are several fittings effectively coupled together, so there is no pipe I can cut and simply rejoin with a union.
I have a total of six cuts I'd have to make: the vertical vent that's about center in the picture, the vertical waste from the second floor, the horizontal drain from the washing machine, and three horizontal spots on the main drain: upstream and downstream from the spot where the stack enters and one from the kitchen that is behind the camera in this shot.
I expect I can use a flexible coupling on the two vents I have to cut. That would help putting things back together. But then I have four drain connections that may need to be done at the same time. I may have a little play in the kitchen connection, but the horizontal drain I expect will be close to immovable.
I also think I may have to replace the footer on the wall due to water damage. I may or may not have all damaged section scraped out. This has to be a load bearing wall as it runs the width of the house on the foundation and effectively separates two halves.
So wise sages: is this beyond mere DIYers? How would you folks go about the repair?
Thank you,
Michael
Thank you,
Michael
