Results 1 to 15 of 20
Thread: How difficult is it to replace the Anode rod
Hybrid View
    DIY Member paulsiu's Avatar
    Jun 2009
    Itasca, IL
    Default How difficult is it to replace the Anode rod
    Hi,
    After reading various article on water heaters, I have a better idea how it works. The role of the Anode rod is suppose to be sacrificial. It rust instead of the tank.
    Then it's logical to replace the rod every couple of years to extend the life of the tank. I was wondering if this is something that can be done by someone who's good with mechanical stuff but has no experience in plumbing. Most articles seemed to indicate that it is difficult because either there is no clearance or the rod gets stuck due to build up.
    Thanks.
    Paul
    Dec 2005
    SW Florida
    It's just bolted onto the top. 1 1/16" 6pt socket for A.O. Smith residential units.
    Matt
    Enjoying life in SW Florida
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    The consensus around here is an impact wrench is the solution.
    I just post cuz I like to see my avatar.
    It's the same concept as the anodes placed on a ship's hull...they get attacked before the hull does, and yes, they do need to be replaced if you want maximum life. The biggest hassle, other than getting the thing loose in the first place, is height. The average home may not have enough overhead room to get the thing out without breaking it (which isn't too bad if required). But, the new ones are available in a few configurations...one has segments that can bend, one is curved, and the stock one is just a straight rod. So, you need to know how much clearance you have. Also, depending on your water, they come in several compositions.
    Dec 2005
    SW Florida
    I did a high-rise project and the owners installed a building softener system without telling us so we could spec the right anode (the decision was made in the 11th hour before getting CO'd. 120 gallon water heaters in each unit and they had to pull the rod out and cut it to get it all the way out. The ended up not having enough room to put aluminum rods in. The GC made plans to eat the replacement cost of the water heaters that now no longer had any anode rods in them.
    120 gallon heaters x 64 units =
    Matt
    Jun 2009
    Itasca, IL
    So the problem is a matter of reach. I think around the heater, it's quite high, so it shouldn't be a problem.
    Any idea whether to use alum or magnesium? One site suggested that magnesium is best because it corrodes slower (and the site said aluminum may be bad for your health). I notice several post on this site citing that using magnesium rod result in rotten egg taste.
    Paul
    Dec 2005
    SW Florida
    Quote Originally Posted by paulsiu View Post
    Paul
    Aluminum rods are used where some filter systems filter out chlorine (at least by my experience). When the chlorine is almost completely filtered bacteria begins to breed in the water heater on the magnesium anode rod. The bacteria generally isn't a health issue but will make the hot water have an egg smell. That's the only situation where I've ever had to spec aluminum rods.
    Matt
    Extreme DIY Homeowner Scuba_Dave's Avatar
    Jan 2009
    South of Boston, MA
    Any problem as time goes on?
    These are threaded in, so maybe checking it every 3 years is a good idea?
    Just to at least keep the thing free from rusting together?
    DIY Handyman (not 4 hire)
    I have enough to do to my own house
