PEX Fittings
Daniel73
I would like to have any info on problems with Watts series 35 quick connects. I am going to install pex line and would aprreciate any knowledge of the quality of the Watts series 35 quick connects.
Kingsotall
Plunger/TurdPuncher
Flagstaff, AZ
We may use you as an axample as I have not heard much about those valves. They are UPC and ANSI certified most likely. The ANSI thing is required now on all supply stops. So if they don't have these certifications turn a blind eye to them. If you end up using them check back in with us down the raod and give us a report.
Tjbaudio
Las Vegas NV
I think that is the same series I have. I picked up a couple of watts caps in varius sizes when I was remodelling. After putting them on and taking them off of copper a few times I had no problems. When under pressure they are VERY hard to get apart. I learned this the hard way when I turned off the water and forgot about the expansion tank on the water heater holding the 60 psi in the lines.
99k
Radon Contractor and Water Treatment
Fairfield Co.,Connecticut
www.78radon.com
I think they are very expensive. I haven't heard of any problems, however, my supply house dropped the entire watts line because they just sat on the shelf and no one used them. I would say most pros only use them to transition from CPVC to another material.
