loudhornsrule
I have been told there is some kind of pipe or pvc to put around a 4'' sub. pump to keep the sand out. What is that and how do you make one, or where do you get it? Thanks Does any one have a pic. of this thing?
A shroud will keep sediment from building up around the motor.
With a shroud, it will pull the sand into and around the pump, and will actually make the problem worse.
