dbouton
- Messages
- 4
- Reaction score
- 0
- Points
- 0
I posted a few weeks back thinking I had a leaky flapper. I replaced it and am still having a problem. What I think is going on is this: I turned the water off going to the toilet. About 10 hours later I took the lid off and half the water had emptied and then stopped leaking. So this told me it wasn't the flapper since all the water would be gone. I put more water in and noticed water leaking into the toilet again (the same place it comes in to refill) which I believe it's called the flush valve (the tube coming up from the flapper where the hose goes into it). I think this has a crack in it at the spot where it stopped leaking. Now I know I could replace it but I will only be in the house about 6 more months because a property management company is buying it and tearing it down to build apartments. So basically I want a quick fix. Is there a "glue" I can put on the crack that will hold. It's a plastic fitting and I wasn't sure if there was something that would hold up once water got on it. Any suggestions would be appreciated!
Dawn
Dawn
