Results 1 to 5 of 5
Thread: OSB for Subfloor?
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default OSB for Subfloor?
    What problems (if any) can be caused by using OSB for subfloor.
    I'm asking because I don't need structural support, just a smoother surface to lay the luan on. You see... It's an old house with 1" thick boards for a subfloor (varying widths and slight thickness differences).
    Thanks for any replies
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Dec 2006
    The edges swells up, if it gets damp or wet. Doesn't hold nails quite as well as ply, either.
    Just use 1/2" ply, instead of the luan.
    Master Plumber Mark:
    do not hit your thumb...
    __________________
    For a subfloor, I like Advantec, but for what you're looking for, ply is better, I think as well.
    Sep 2006
    cold new york
    Quote Originally Posted by frenchie View Post
    I'll ditch the OSB idea. Can I lay linoleum directly over 1/2" ply and not have problems? What treatment do the seams receive?
    Thanks,
    Molo
    Gore Vidal.
    Yakima WA
    The problem with regular plywood is there may be voids here and below the top ply. A sharp weight such as an appliance or woman's high heel can break through. What you should use as an underlayment is called multiply. It comes in 1/4"x4'x4' sheets and may have different names. It's like plywood, but it has no voids. As I recall, it isn't much different in price from plywood.
