We use two most of the time.
If the flange is setting on the finished floor, you can use one wax ring.
If the flange is on the subfloor, and the underlayment has been cut around the flange, you need one regular wax ring first, then you can drop a second ring down. We normally use a wax ring with horn as the upper wax.
Then drop the bowl down on the wax, have two door shims handy in case the floor is not level and shim at the back, pinning the front of the bowl down to the floor.
Plumbers will use closet bolt sets with four nuts and four washers.
We secure the closet bolt to the flange before the bowl is set.
This way that bolt doesn't fall down while positioning the bowl and does not slip out while cutting or trimming the bolt so the bolt cap can be installed.
There is nothing worse then having to pull a bowl filled with water because of a "slipped bolt".
Plumbers do not put wax rings on bowls, plumbers put the wax on the floor, and then drop the bowl down.
The picture on the box can create many problems when the wax falls off and blocks the drain hole.
