twinsrusracing
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I was wanting to install a grey water recycling setup in my house where all the toilets would be filled with grey water from showers,sinks in my house to cut down on water consumption. Here is my plan, both toilets in my house will be supplied seperatly from the rest of the plumbing so no cross contamination will occur. I plan on having a closed container in my basement which will hold the water coming from the bathroom sink and shower only. Probably about 25-30 gallon capacity. I will have an overflow near the top of the container and it will be hooked to the main sewer pipe and exit the house like the rest of the waste water. My problem is I need some sort of small pump or pressure tank to pump water back up to the bowls of my toilets from the grey water container when the toilets are flushed. I know there are some kits outthere for about 300.00 but I am on a budget. If anyone has any ideas or pros and cons of this type of set up I would appreciate it. Thanks!
T.J.
T.J.
