Results 1 to 2 of 2
Thread: faucet set in deep well
    Default faucet set in deep well
    Scenario: bathroom vanity sink from 50's. Trying to remove faucet. Cannot access or remove the nut that secures the faucet against the porcelin from underneath. Basin wrench can't turn because the "well" is so narrow. Copper connections from faucet spout to hot/cold turnoffs make it like one piece. How did they ever get it in there and is there no way to get it out? I have progressed to the point where the hot/cold valves and connections would just drop out underneath IF they could be disconnected from the faucet part but then I would still face the problem of lossening the nut that secures the faucet. The faucet can't be budged from the top....ack
    Linda
    DIY Senior Member Mike Swearingen's Avatar
    Jan 2005
    On Albemarle Sound In Northeastern NC
    Wear a heavy work glove and use a hacksaw blade to cut the nut under the sink by hand. Once cut, tap it off with a hammer and chisel or large flathead screwdriver to remove it.
    Good Luck!
    Mike
