Tony from N.C.
I installed my own irrigation system. I now call irrigation irritation. I don't know how men do this for a living. I would factor in a number for cutting wires and anything else in the ground and go wild. Thats a different story in its self. I had a shallow well drilled (irragation only)4 inch hole with a 2 inch pvc pipe. The well is 80 feet deep the casing is 40 feet deep with a static line of 9 feet. The well was rated at 30 gpm. I installed a 1 1/4 suction pipe with a foot valve on the bottom. At the top of the well I changed the suction from 1 1/4 to 1 1/2 and ran it over to my well pump 20 feet away. I have a 2 hp. flowtec shallow well pump. I have a pressure gauge on the pump and have wired the pump 220v. The output side of the pump is put into a manifold to 1 inch. The question is ? The pump pressure will vary from 20 psi to 35. I understand different zones have different flow rates. Im talking about the same zone will vary from 20 t0 35 psi. My irragation run much better at 35 than 20. I have also install a check valve befor my pump so the water doesn't back feed back into the well. The check valve has a very small spring. I have asked everyone in the area and they all blame me the well driller the pump knowone has a real answer. I would like to have the pressure at 30 psi. I have pulled the suction pipe out and checked the foot valve and its clean and have redone the suction pipe so that the is no air leaks. I would like to make the pressure more of a constant pressure. I have seen the special pumps made by flowtec to build more pressure(booster pump). The money isnt the problem I would like the system to work well every time. Thank you Tony from N.C.
