Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Drain for Jacuzzi Espree 6060 corner?
    Default Drain for Jacuzzi Espree 6060 corner?
    Very strange, I cant seem to find one? Lowes had no clue and it is too late to call jacuzzi. Is it a special one made just for jacuzzis or can i go to lowes and buy a fits most type?
    thanks
    DIY Junior Member bcolombrito's Avatar
    Jun 2005
    Chesapeake,VA
    Default espree 6060 drain
    I am about to purchase same tub from lowes... did you find your drain kit or am I in for the same issues?
    Default drain
    Unless there is something special about that tub, a "generic" drain assembly should work, although it may have to be one that can be extended to accomodate the higher rim of that model tub.
    we got the generic one from lowes. but it did not fit. the overflow drain runs right into one of the pump hoses. so i went to home depot and got a 1 1/4 flexible hose, clear with cross threads through. and the fittings to fit it to the pvc. that worked. i have pics if you would like. let me know.
    Default experience with this Jacuzzi tub
    Hi, I am considering buying this tub from Lowes. Do either of you recommend this model and what are your experiences?
    Default jacuzzi espree 6060 tub
    I am considering buying the Jacuzzi espree 6060 tub from Lowe's. I read the previous posts from two years ago. I am wondering if anyone has had experience with this tub. If they like it? If they had the drain issue described in the previous posts?
    Well, I plunked down the dough and bought the 6060, I'm starting the install right now... but as I read through the instructions it vaguely tells me that I need the drain/overflow assembly (sold separately) before I start installation. Grrrr.
    I am going to head to Lowes tomorrow and ask about this... but I figure that they won't know and I'll have to piece it together. Why wouldn't Jacuzzi just include this with the tub? I paid around $1300 for the skirted model.
    Anyone own this and able to give us their comments about the tub?
    Most sell the drain separately since it likely comes in brass, chrome, satin nickel, etc. there are probably at least a few companies that make a drain that would work, and Lowes may not have the biggest choice or quality.
    Well, Lowes had a cable-driven bath drain that they sold me for about $65. It still didn't really fit, so I ended up adding a 22 1/2 degree ABS elbow into the long run between the overflow/knob and the T-pipe below so that the pipe would clear the Jacuzzi innards. It is working like a charm.
    Now my second problem, it appears to me that Jacuzzi forgot to install the inline "rapid heat" heater. I don't see it anywhere. I'm assuming that it should be right in the front when I look in the access panel, but nada. Grrrr. If anyone has a 6060 can you please confirm the location of the heater?
    I am planning to purchase this model from lowes and was looking on their website and really like the platform in the pic. It doesnt look like tile on the top can somebody tell me what they use instead of tile. Also when doing that do you change the rough in dimensions for the size surround?
    Do you mean this photo?
    http://images.lowes.com/product/731352/731352523854.jpg
    Looks like its wood to me, painted white. The rough opening would still be the same as the instruction specs state.
    Here is my installation so far... I'll post photos when its finished.
    http://picasaweb.google.com/darrendr...52364583741250
    By the way, Jacuzzi DID forget to install the inline heater on my unit. They are second-day airing me the heater.
    The guy at Lowes tried to tell me that Jacuzzi just changed the specs on the 6060 to include the heater, but they had a 2006 catalog sitting on the counter that showed it was a standard feature two years ago. He looked a little embarrassed when I caught him in the fib, but he wasn't really from the plumbing dept, so I think he just said that to sound smarter.
    Thanks, Thats the pic I was referring to. Good luck on yours.
    Default Platform
    I purchased the non-skirted model. A platform was constructed of 2x4's and marble attached to the top side along with a back splash along the wall. Intend to add finished framing along the front with pop out access panels.
    Wow, remember back on the 27th when I said that Jacuzzi was 2-day air-ing my heater to me? Well its been over two weeks and I still haven't gotten it!
    Last Friday I complained to Lowes and they called Jacuzzi... no one had shipped my heater out. So again I was told it would be shipped.
    On Wednesday I went BACK into Lowes and bitched... they called again and the woman at Jacuzzi said she had forgotten to ship it, but she would make sure it went right out. That means I should have seen it today. Guess what? Nope.
    So I just drove down to Lowes, got the contact information for Jacuzzi (Lowes has a special phone number for them) and called. It turns out that the heater didn't ship Wednesday or yesterday, but he said it shipped today. I'll believe it when I see it on Tuesday.
    It seems like the guys over at Jacuzzi have their heads up their asses and can't get anything right. To make matters worse I spent three hours trying to diagnose a leaky toilet that I just installed the other night. There was a manufacturing defect in a crevice under the bowl that caused water to leak everytime the toilet was flushed. I installed the toilet three times, with three separate wax rings before I realized that wasn't the problem. Guess the brand of my toilet? You bet: Jacuzzi. Unfortunately I have three more Jacuzzi toilets going into this old house. (sigh)
    I'm at the end of my rope... at this point I will never buy another Jacuzzi product again.
  1. Jacuzzi Espree HET toilet, EZ36959
    By Baron in forum Toilet Forum discussions
    Last Post: 09-09-2009, 11:25 AM
  2. jacuzzi 6060 corner tub
    By VApops in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2009, 02:58 PM
  3. Installing jacuzzi 6060 whirlpool bath
    By jjrausch in forum Shower & bathtub Forum & Blog
    Last Post: 06-04-2008, 05:07 AM
  4. jacuzzi espree tub leaks
    By dshepp in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2008, 12:35 PM
  5. Jacuzzi "Espree" corner whirlpool
    By hsullivan in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2005, 11:33 AM
