I have a pump. It says that it is a convertible jet pump made by Simers with a GE 1/3 hp electric motor. As you look at it on the bottom front is 1 1/2" opening were I have my intake. On the top front is a 1" opening with a plug. On the top is another 1' opening with a plug, a small opening where the pressure gauge is and, another small opening with a plug and pipe connecting to the pressure switch. On the right side is two about 1 1/4" openings, the top one I have my discharge pipe and the bottom one has a plug. I have a 2" pipe with a 3 foot sand point in the ground 17 feet with 6 feet of water in the pipe. I have 2" cap on top of the pipe with a 1" heavy plastic pipe with a check value connecting to the pump. Any ideas why I can't get water up to the pump.
