Results 1 to 7 of 7
Thread: Silicone caulk vs. latex caulk
    Default Silicone caulk vs. latex caulk
    We are in the process of installing a sink vanity and the manufacturer's directions say to use a latex caulk. Is it okay to use silicone instead?
    Thanks.
    Default caulk
    Yes, it may just be messier.
    Dec 2007
    The mess... There will be one, can be cleaned up with Denatured Alcohol and a rag...
    Feb 2005
    Talking use the latex....
    if you use DAP or latex caulk you will be fine.....
    if you use the silicone caulk, then you are pernamently
    installing that sink, because the silicone will never allow
    you take that sink out ever again is is in for good and will
    have to be broken to get it back out.......
    you only have to make this mistake once.....
    god created all men,
    Latex it is then. Thanks!
    Jul 2007
    USA
    Let's just put something out there.
    Latex definitely to sit a sink on a vanity or to seal the gap against the wall but I would only use silicon to seat the drain against the sink.
    I used latex on my utility sink drain and it developed a leak. I redid it with silicone and now the leak has gone.
    Dec 2007
    Plumbers Putty works well for setting drains.
    I do not advocate gluing things in with Silicone RTV.
