Solan
- Messages
- 9
- Reaction score
- 0
- Points
- 0
Hello. I'm brand new to the forum here and by the looks of the good advice being given out here - I could have used this a long time ago. I'm an accomplished DIY'er and know my way around plumbing a bit (not a pro but my local inspector likes my work). I'm located in Los Angeles and my set up is as follows:
- 50 Gallon G.E. gas water heater (2 years old) temp set to 125 degrees.
- Watts PLT-5 Expansion tank (2 years old) installed just after the hot water heater tank shut off and with a pressure gauge just before the expansion tank.
- Wilkins 600 series PRV. (Making a closed system). Pre-valve pressure is 180 psi. Post valve pressure is 60 psi.
- Wilkins PTV valve right after PRV (before it enters the crawl space).
My questions are:
My PTV valve started leaking recently I tried a new valve (still leaks). Then I tried recharging and reinstalling the expansion tank but I'm still getting a leak. How likely is it that the expansion tank has failed after just 2 years? If it has how can I be sure it's dead and that it's the cause of my leaking PTV valve?
Any info is greatly appreciated. I can provide a pic in necessary.
Thanks,
Solan
My questions are:
Thanks,
Solan
