dieselburner
- Messages
- 2
- Reaction score
- 0
- Points
- 0
Hi, I just installed a new well and a CSV2W cycle stop valve. I have a 25GPM submersible pump and an 86 gallon pressure tank. My question concerns setting the pressure switch on the pump to work properly with the cycle stop valve. The instructions that came with the valve instruct to establish a 6-8gpm flow rate downstream of the valve and then adjust the valve to 10 psi higher than the desired system pressure. Since I would like to have 60psi on the system, I adjusted the cycle stop valve to 70psi at 7gpm flow rate and had to raise my pump shut off pressure to 75 psi. Does this sound right? Thanks
