Just remodeled and put in a second open loop heat pump. New heat pump is two stage with total water usage of 7 gal/min. We also have an open loop heat pump in the original house that we will probably replace with a similar open loop that will probably require at least 7 gpm. Current rock well is 30 years old, 4 inch steel casing, 248 ft deep, with 20 year old 1/2 hp submersible pump. Current feed line is 160 psi 1 inch. Water level is 29 feet below ground level and current pump sets 69 feet down with 1 inch drop pipe. Current bladder tank is Well-X-trol 302 (35 gal.?) We think we're only getting about 8 or 9 gpm with current system.
We put in a new 1 1/4 160 psi plastic feed line and 10 ga 3 wire w/g under new addition foundation that leads out to where we could put in a new well or run the wire over to the existing well if that is an option. Current well/pump is 12-2 w/g wire.
We'd like to upgrade to a new well/pump system that would give us between 20 and 25 gal/min to accommodate both heat pumps and regular water demand. I guess we have four options.
1. Use current well and replace the current pump with a bigger hp pump if it will supply us with the water flow we need. Use everything currently in place, tank etc.
2. Use current well and replace pump with Franklin 1 HP 20 gpm submersible pump and 60 psi constant pressure mechanical valve with 1 1/4 drop pipe. Some well people say the mechanical pressure valve is bad on the pump and that pump manufacture does not guarantee pump, ie. warranty is void. We wonder if it's good for the pump to try to pump all that water against the valve during low volume demand which seems to me would create a lot of back pressure.
3. Use current well with 10/3 w/g wire and Franklin Electric SubDrive constant pressure system to produce up to 25 gpm. How susceptible are these systems to lightning damage? We have friends with this system that have had to replace the control system twice due to lightning or electrical surge.
4. Drill a new well with a whole new system. What would you recommend?
We would very much appreciate detailed input and recommendations for our well and water system. Thank You!
