Thread: Room Temperature Offset
    Default Room Temperature Offset
    What does it mean to offset your thermostat? Is there a way to set the AC for a certain temperature and then for it to come back on after the temperature of the room has increased say 2 or 3 degrees higher?
    Nov 2006
    Quote Originally Posted by rtorrez View Post
    I have just done some searching, and the only info I can find on "offset" has to do with calibrating (correcting?) the display by up to +/-7 degrees.
    Thermostats typically have anticipators for that kind of purpose, and that function can be adjustable. I believe one of mine allows for selection between a broad range and a narrow one.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    I would call that a differential, not an offset, but most t-stats have the option to set this differential from .5 to 3 or more degrees. Most newer programmable T-stat will have these options.
